Varias fallas en GLI 2006
3 replies to this topic
#1 The Metal God
The Metal God
  • 941 Mensajes:
Escrito 27 April 2013 - 09:47 AM
Hoy en la mañana revise un GLI 2006, me arrojo muchisimas fallas, pero las que de plano no supe a que se puedan deber son las que aparecen en la foto y el modulo de AIR BAGS, que nunca pude accesar a el
Alguna sugerencia?
Gracias!!
VCDS Version: Beta 11.2.0
Data version: 20110305
Saturday,27,April,2013,08:44:51:10074
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
VIN: 3VWXJ71KX6M707999   Mileage: 88050km/54711miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 B    HW: 1K0 907 115 B
   Component: 2.0l R4/4V TFSI  00 0010
   Revision: --H10---    Serial number: VWZ7Z0E2511964
   Coding: 0403010A1C070160
   Shop #: WSC 00066 000 00000
   VCID: 2545F5A79721
15 Faults Found:
001537 - Internal Control Module: Memory Check Sum Error
               P0601 - 001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 82366 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:45:04
             Freeze Frame:
                    RPM: 980 /min
                    Load: 46.6 %
                    Speed: 0.0 km/h
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 900.0 mbar
                    Voltage: 11.811 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 0
                    Fault Frequency: 30
                    Mileage: 82381 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:40:54
             Freeze Frame:
                    RPM: 770 /min
                    Load: 13.3 %
                    Speed: 0.0 km/h
                    Temperature: 91.0°C
                    Temperature: 53.0°C
                    Absolute Pres.: 770.0 mbar
                    Voltage: 13.589 V
000665 - Boost Pressure Regulation: Control Range Not Reached
               P0299 - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 82523 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:56:51
             Freeze Frame:
                    RPM: 3782 /min
                    Load: 74.1 %
                    Speed: 101.0 km/h
                    Temperature: 88.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 890.0 mbar
                    Voltage: 13.716 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 84887 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:16
             Freeze Frame:
                    RPM: 2039 /min
                    Load: 16.9 %
                    Speed: 0.0 km/h
                    Temperature: 28.0°C
                    Temperature: 27.0°C
                    Voltage: 11.684 V
001109 - EVAP System: Large Leak Detected
               P0455 - 001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 84888 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:14:03
             Freeze Frame:
                    RPM: 1649 /min
                    Load: 25.9 %
                    Speed: 64.0 km/h
                    Temperature: 77.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
               P310B - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 11
                    Mileage: 84930 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:59:20
             Freeze Frame:
                    RPM: 2180 /min
                    Load: 46.6 %
                    Speed: 7.0 km/h
                    Temperature: 101.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 860.0 mbar
                    Voltage: 13.716 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 11
                    Mileage: 85039 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:31:59
             Freeze Frame:
                    RPM: 1327 /min
                    Load: 12.9 %
                    Speed: 35.0 km/h
                    Temperature: 85.0°C
                    Temperature: 52.0°C
                    Voltage: 13.843 V
004243 - Bank 1; Fuel Measuring System 2: Malfunction
               P1093 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 85048 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:12:22
             Freeze Frame:
                    RPM: 1524 /min
                    Load: 11.8 %
                    Speed: 41.0 km/h
                    Temperature: 90.0°C
                    Temperature: 62.0°C
                    Voltage: 13.081 V
008825 - Leak in Air Intake System
               P2279 - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 85072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:02:25
             Freeze Frame:
                    RPM: 776 /min
                    Load: 14.5 %
                    Speed: 0.0 km/h
                    Temperature: 93.0°C
                    Temperature: 56.0°C
                    Voltage: 13.716 V
000313 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
               P0139 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 8
                    Mileage: 86629 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:45:56
             Freeze Frame:
                    RPM: 1196 /min
                    Load: 12.9 %
                    Speed: 32.0 km/h
                    Temperature: 95.0°C
                    Temperature: 47.0°C
                    Absolute Pres.: 880.0 mbar
                    Voltage: 13.589 V
004372 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
               P1114 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 86629 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:45:57
             Freeze Frame:
                    RPM: 1530 /min
                    Load: 11.8 %
                    Speed: 52.0 km/h
                    Temperature: 93.0°C
                    Temperature: 57.0°C
                    Voltage: 13.335 V
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 86716 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:51:58
             Freeze Frame:
                    RPM: 853 /min
                    Load: 26.3 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 63.0°C
                    Voltage: 13.589 V
000769 - Cylinder 1: Misfire Detected
               P0301 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 86716 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:53:11
             Freeze Frame:
                    RPM: 1198 /min
                    Load: 17.6 %
                    Speed: 14.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Voltage: 13.208 V
000770 - Cylinder 2: Misfire Detected
               P0302 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 86716 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:53:11
             Freeze Frame:
                    RPM: 2031 /min
                    Load: 52.1 %
                    Speed: 27.0 km/h
                    Temperature: 83.0°C
                    Temperature: 54.0°C
                    Voltage: 13.335 V
000771 - Cylinder 3: Misfire Detected
               P0303 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 87278 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:11:42
             Freeze Frame:
                    RPM: 1146 /min
                    Load: 32.5 %
                    Speed: 0.0 km/h
                    Temperature: 36.0°C
                    Temperature: 24.0°C
                    Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AE
   Component: GSG DSG         070 0927
   Revision: 04507000    Serial number: 00000507190714
   Coding: 0000020
   VCID: 214DE1B78309
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0021122
   VCID: 408B44336843
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 67D9BFAF2DAD
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000000188769
   Coding: 07078E234004180000140000001400000028770B5C
   VCID: 2B51039FF1C5
   Subsystem 1 - Part No: 1K1 955 119 C
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00066
3 Faults Found:
01501 - Bulb for Blinkers; Rear Left (M6)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 65
                    Mileage: 52078 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.30 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00988 - Lamp for Brake Light; Right (M10)
             Freeze Frame:
                    Fault Priority: 1
                    Reset counter: 65
                    Mileage: 53356 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 31
                    Reset counter: 65
                    Mileage: 37613 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.50 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7E6011793
   VCID: 2A5F069BFE3F
2 Faults Found:
02635 - Tuner Not Enabled/Activated
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 84887 km
                    Time Indication: 0
01304 - Radio
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 84887 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:20
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0012121
   VCID: 7AFFF6DB4E1F
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972 A
   Component: KOMBIINSTRUMENT VDD 1212
   Coding: 0023203
   Shop #: WSC 26060 993 01245
   VCID: 306B14F3D8E3
1 Fault Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010590789B8
   Coding: 7F3F03600F1002
   VCID: 2A5F069BFE3F
2 Faults Found:
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 65
                    Mileage: 67729 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:50:20
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 105
                    Mileage: 37613 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:27:12
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1293324T0M6001
   Coding: 0000003
   VCID: 397D29D70B99
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 87
                    Mileage: 34725 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:05:59
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1212
   VCID: 306B14F3D8E3
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 366722EB3A87
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326F1EFBD6EF
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 1B900E880106281B0904058FB0080F0480A540
   VCID: 820F0E3BA6CF
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
1 Fault Found:
00668 - Supply Voltage Terminal 30
             Freeze Frame:
                    Fault Status: 01110010
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 248
                    Mileage: 0 km
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 37792FEF3D8D
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4E358E3EC7B
1 Fault Found:
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
            010 - Open or Short to Plus
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 316D11F7D3E9
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 326F1EFBD6EF
End   ---------------------------------------------------------------------
#2 Acero
Escrito 27 April 2013 - 07:05 PM
Pues empezaría por fallas del motor y para no empezar a gastar seria darle una limpiada a la bomba de gasolina y cambio de filtro de gas, aquí es limpiar los cedazos de tela de la bomba con cepillo de dientes yo lo puse en fotos como se ve el contenedor de la bomba y como se limpio borrar y probar por lo que mencionas de las bolsas de aire pues para que no de acceso ver que los fusibles esten bien conectados y no abiertos, verificar si no hay adapataciones de estereo o luces o alarma o ver si no trae inquilino roedor jeje pues eso seria basicamente lo que podría provocar fallos o reles que pudieran estar mal.
#3 Rufflex
Escrito 29 April 2013 - 01:27 PM
PEro es de siniestro no?
ese error te lo maca cuando el detonador fue activado, osea se activaron las bolsas, hay que cambiarlo y ajustar todo de nuevo.
Trae hasta los focos del stop fundidos, hay muchos faciles de resolver, otros si llevan un poco de tiempo.
Despues de borar codigos volvio a salir todo?
#4 The Metal God
The Metal God
  • 941 Mensajes:
Escrito 29 April 2013 - 04:58 PM
no quizo que se le borraran
