DB Drive SPA1600D VS OKUR A3 1500.1D
No replies to this topic
#1 hostilito
hostilito
Escrito 14 May 2011 - 08:48 AM
DB Drive SPA1600D o OKUR A3 1500.1D
Que onda raza,
pues tengo una duda de cual amplificador comprar estoy entre el DB Drive SPA1600D o OKUR A3 1500.1D. son solo 100watts rms de diferencia eso no importa mucho, la duda que tengo es cual es mejor amplificador de los 2 ya que la serie OKUR es nueva.
entonces los que an tenido esperienncias en estos amplificadores den su opinion porfa o si saben cual es mejor de los 2 pues mejor jajaj
DB Drive SPA1600D
Product Description
Brand new DB Drive SPA1600D 1,600 watt class "D" car amplifier with free bass remote control Features: DB Drive SPA1600D 1,600 Watt RMS mono class "D" amplifier 1 x 1600 RMS @ 1 ohms @ 14.4 Volts 1 x 800 watts RMS @ 2 ohms @ 14.4 Volts 1 x 400 watts RMS @ 4 ohms @ 14.4 Volts Continuously variable 18dB per octave low pass crossover (40 Hz - 250 Hz) Subsonic Filter: 20 50Hz 1 ohm Stable Continuously variable 18dB boost on bass EQ @ 45 Hz Class "D" Fully Digital Circuitry Very Efficient and Low Current Draw Variable subsonic filter (20-50Hz) Direct-connect integrated speaker and power wire terminals DC-DC PWM power supply Bipolar outputs Buffered pre-amp input circuitry DriveSink heat management system Audiophile-grade components Built in cooling ventilation technology to keep the amp cool Short, DC Offset, Thermal, and Overload Protection Power Indicator Power and Speaker Distribution Blocks Built In for Maximum Power and Signal Transfer with Minimal Resistance Adjustable Input Sensitivity Remote Turn On Pre-Amp Outputs Included remote bass control Dimensions: 2.52"H x 9.64"W x 13.79"D
DB DRIVE OKUR A31500.1D
Características Generales
Amplificador mono block A3 1500.1 DB DRIVE
Potencia 1 Ohm =1500W 14.4 volts
2 Ohm =750W 14.4 volts
4 Ohm =325W @14.4 volts
Potencia maxima dinamic power 1500 W
Impedancia 1 Ohm
THD N/A
Frecuencia (X over) 40 Hz - 150Hz
Bass boost Si
Fusible 20 amp X4
Corriente/tierra Calibre 4
Clase Clase AB
Controlador de bajos Incluido
Filtro subsónico 15 Hz-55Hz
Función máster Slave Si
Indicador de encendido (LED)
